See here for vendor pix and text: https://www.ebay.com/itm/177219385670 Click on "See original listing" for pix.
Cleaned up a little with minimal and non-aggressive methods. Discoloration on blade and handle is not pitting, but surface only. Paid $205.
Very Dk Brown leather scabbard was "just" starting to crack (very dry), so applied some Pecard's oil inside and out; this will preserve in current state for a Long time. Female snap fastener (Line 20 size) was improperly set (loose), so re-set it using appropriate tools so that snap halves grip the leather tightly and won't tear out.
As received, knife can stand some sharpening, and I will investigate related topics. I have the tools and skill to "do it right". Blade steel IS magnetic.
Serrations on sides of handle and on the guard are well-executed and still sharp. Matching numbers of serrations side-to-side. This serration was done by someone who took care and knew what they were doing, and not your average "Bubba". Kinda scratching my head at locations of serrations, though. Some might think that an "experienced" person would have cut "thumbprints" (a la V-42) into the wider sides of the handle and guard. Less hassle, and better for gripping the blade when blade is in a horizontal orientation. But what do I know?
So, for Questions:
1) Is it genuine or some sort of fake?
2) Is the very low Serial Number credible?
3) Why was the black coating seen on every other Mk 1 knife removed, or was it possibly never applied due to the serrations?
4) What is the likely steel used in the blade?
If It's a valuable rarity, can I carefully sharpen the blade to original edge contour without diminishing whatever value it has?
If it's NOT a valuable rarity, can I gently glass-bead blast the handle, which would remove surface discolorations and provide an ideal surface for Brownell's Aluma Hyde II Epoxy paint?
It may be possible to very gently polish out the surface discolorations on the blade, as well as some edge scratches visible in the pix.
Comments invited, please. If I got screwed, let me know.
So, for Questions:
