sweetcostarica
BANNED
- Jan 18, 2012
Just received a Tora BSI 1960's in the mail and here it is vs. a normal Khukuri House BSI.
Above (left): Tora BSI and next to it (right) an average Khukuri House BSI
Below: Khukuri House is the knife on top
Below: the Tora's (L) handle is larger and much more comfortable (IMO). I have XL hands though.
Specifications
Khukuri House BSI Service No. 1:
Length/Blade: 27 cm (10 1/2 in)
Length/Handle: 10.8 cm (4 1/4 in)
Length/Overall: 39 cm (15 1/4 in)
Belly width: 4.5 cm (1 7/8 in)
Spine thickness at point: 4 mm (3/16 in)
Spine thickness at belly: 9 mm (11/32 in)
Spine thickness at Bolster: 10 mm (.39 in)
Weight: 555 grams (19.60 oz)
Tora BSI Service No. 1:
Length/Blade: 29.2 cm (11 1/2 in)
Length/Handle: 12 cm (4 3/4 in)
Length/Overall: 41.5 cm (16 3/8 in)
Belly width: 5.5 cm (2 1/4 in)
Spine thickness at point: 3 mm (1/8 in)
Spine thickness at belly: 7 mm (9/32 in)
Spine thickness at Bolster: 8 mm (5/16 in)
Weight: 458 grams (16.15 oz)
The new 1960’s Tora BSI Service No. 1 when compared with an average Khukuri House BSI Service No. 1 seems to win in every department except for probably splitting wood. That’s where the thick wedge like spine of the heavier KH’s knife over powers the Tora.
So as seen in the pictures the Tora BSI is longer, has a wider belly, bigger handle, it is thinner, lighter, and has a much better hollowed ground blade.
I have also noticed the KH BSI has very bad balance and the Tora is so well balanced you would think it is 50 to 100 grams lighter. This good balance is common with the Tora Military Line.
Specifications
