- Dec 29, 2016
Okay team, couple questions here but first some show and tell, and some explanations. So, i have a bevel grinding jig that i'm not using in this & a plunge jig w/ carbide faces that i'm not using, but i've been trying to grind a knife now with my last couple of blanks. I'm new, still trying to get something to send to heat treat so i can begin to practice the rest of the skills in this art.
Steel i'm working with is AEB-L, cut out on a bandsaw, and using some designs i threw my own ideas at. I don't know if i should pick a design and have a million of it water-jetted out and keep practicing, if i'm using the best steel, AEB-L seems to be fantastic to work with so i currently have 2 11x24 sheets of it. Also have some CPM 3V i'm going to save now til i figure my shit out.
Struggling in a couple areas, i always grind to thin, way past my center marks and i now believe i have a knife that won't survive heat treat. I also struggle to freehand it all, the below chefs knife was knife #2 ground free hand ever, and basically 4-5th knife ground ever (tried the jig a couple times and ruined some stuff. I definitely feel like i'm getting a hang of it, but i guess my questions are as following:
1.) Whats the best steps to take to practice grinding (with or without the jigs), i really want to make chefs knives, so should i just get a ton of them and little paring knives cut out (water jet, have a friend who gives good rates) to practice, what steel should i go with, the stuff i'm working with currently is .125 or .136 thick.
2.) Belt progression - i think a lot of my ails come here, i rough my 45's in with a beat 36 git norton blaze, then did most of everything with a 60 grit norton, but it seems to move to quick, and i can't correct without running or diving deeper into my edge or my knifes spine...Any advice here would be rad.
The grind line i was going for, apparently my left side is my strong side????
Weak side i guess, the grind kept climbing and maybe i was just using to much pressure and making to many mistakes to quick.
