Hi folks
My first post. Great forum, been reading it for a couple months now!
Made a beautiful charcoal forge to anneal my file knife and apparently it worked too well. Too much air flow and ended up melting tip off. Got through the first quench ok but went for 2 and then ruined it. Oh well ... ground it down a little smaller and finished the blade today complete with a blue and black jean micarta handle.
Had air flow from hair dryer on low so maybe incorporate a dimmer switch as well for the next one.
My question is regarding the above mentioned angles. If you stuck to 20 deg grind and 30 hone then the actual grind angle only travels about 3/16 or 1/4 inch up the blade towards the spine. It kind of looks silly. On my first attempt, (the one that I melted) I just went with what looked good, and that was about 5/8 inch up, but without doing any calculations that like about a 8 deg angle. so in actuality there would have only been the cutting edge grind really.
Is there such a thing as a tripple grind? Like the 8 deg then the 20 and finally the 30?
Just wanted to try a couple before my 1084 is delivered.
All comments and suggestions will be greatly appreciated.
Grant
Grant
