- Aug 13, 2009
Steel is cpm154
I’m a hobbyist who makes a small batch of knives every so often when the urge hits me - so I’ve always sent my knives out for heat treat. The last batch of blades recently came back and one had had a warp in the tang (first time this has happened to me), too much to grind out. So with nothing really to lose, I applied heat stop paste on the blade, and clamped it between two aluminum bars in the vise. I heated the bend and straightened the warp. The blade stayed perfectly cool, and I was happy. But now I’m worried the spot I heated up will be brittle. Ive sent a message to the heat treater I used but haven’t heard back yet.
So my questions are:
- would that spot now be brittle? (I just let it cool at room temp)
- I read cpm154 can be tempered at as low as 400 degrees for two cycles of 2 hours each. So if I did that, would that help? Would that change the hardness of the rest of the blade?
Anyways, I appreciate any advice
DG
DG
