...I'm hoping someone could point me in the right direction for where to get proper steel for the job...
First, before anything, I believe you deserve a round of applause for making the choice to start off with the correct material:thumbup: with this approach you will be a "newbie" for a much shorter time than many others.
I know Mr. Cupples offers lots of good steel, and I certainly know what Mr. Bruno offers and I spend a certain amount of time on the phone talking with Aldo about the ins and outs of various steel alloys, he likes to know what his steel is and what it is going to do.
...I'm not looking for anything in particular. Just something good for a wood working knife...
You’re on the right track but don't get turned around now... Look for something in particular. The single most important decision you can make in increasing your chances of success is proper steel selection for your application. I now believe that one the greatest stumbling blocks in methods for modern knifemakers is trying to use heat treatments to force a poorly chosen alloy to do a job it wasn't designed to do, if you would be willing to work with me in this thread I think it could be a great learning tool to take a methodical step by step approach to your steel selection.
The very first thing you do is determine exactly what the blade will have to do- slice, chop, cleave, shave, shear, pierce etc... and then determine where and how it will have to do it- the kitchen, the workshop, the woods, the ocean, etc... Next one of the most important but too often overlooked- what are your tools and skill level for working that steel?
After you determine these things you will then be able to choose almost the exact alloy you need according to how its chemistry matches your needs.
Don't be intimidated by this this is not even as tough as high school level chemistry, I promise
. In most of the steels we will ever work with there are less than a dozen elements we ever have to worry about other than the obvious iron (Fe) and these are the ones you will mostly see- C, Mn, Cr, V, W, Mo, Si, Ni.
Start with the most common and work toward the rarer stuff that is added for special effects. Carbon would be the first; it will determine your maximum hardness (thus overall strength) and abrasion resistance. C < .8% for choppers, C > .8% for slicers, C = > .8% for a bit of both in a general using knife. Your wood working knife will be one of these depending on the most common woods cut, if it is cut with hand pressure or if you will be using a mallet. The mallet on very dense wood may require around .8%, but a fine cutter that will be pushed by your finger will enjoy extra carbon. This comes with one caveat- the more free carbon content; the more skilled you will have to be for success.
Look for things like V and W to help out with this extra carbon, it can lock it up into extra hard carbides that will keep your blade cutting longer, but will make it so your steel will not tolerate a lot of monkeying around with temps and cooling rates. Cr will also add carbides but to a lesser extent and is more useful in increasing the depth of hardness. At your point in you knifemaking career keep heating to a minimum number of times (just hardening and tempering) when these elements are present.
Hardening the steel comes in two steps- heating (austenization) and quenching. These elements will effect either or both, and at times be at odds with the other. There are two reasons a blade doesn’t harden- it didn’t get enough heat (temp, or time at temp) or it didn’t get cooled fast enough. Mn, Cr, Mo and Si, make the cooling part much easier, total absence of any of them would require water or brine for maximum hardness, but adding greater amounts of any of them will allow the quench speed to be less extreme from various oils to eventually air when enough Cr is added. The catch it that the more effect the elements has on quench speed the more the opposite effect it has on soak time at temp. 1080 steel has none of these but a little bit of Mn so it must be quenched rather fast, but on the other hand it can be heated very quickly with a forge or a torch with little problem. O1 steel has plenty of Cr, W, V and Mn, it can harden in a slow oil but will take a longer time at a precise temperature to get things right. Think of these elements as hanging onto your carbon for you so the soft stuff can’t use it, it takes time to convince all of these elements to hold your carbon for you but once you do the soft stuff will not be able to run off with it when you quench. But without any of them present you don’t have to worry about convincing them so you just get it hot and do your best to outrun the soft stuff.
If you are just in your workshop Cr and Ni may not be useful in amounts greater than 2% but if you are going outdoors and particularly near the ocean you may want a lot of them for help in keeping the rust away.
At this point I would say your decision hinges on what tools and equipment you have at hand to get the most bang for your buck from your steel. Kiln/oven? Torch? Forge?
