Newbie maker looking for some recommendations
So first I would like to post my second and third ever knives. Both folders, both roughly the same size (~3.5" blade). #2 is an S30V blade with a titanium frame lock, and #3 is an AEB-L blade with titanium liner lock, spalted oak scales, and brass spacer. Lockup on #2 is perfect, no play in any direction whatsoever. Lockup on #3 is a bit loose, I was over ambitious trying to polish the lock face. Not horrendous, but it is noticeable. I did the heat treat on both myself in my new forge, so I'm not positive of the hardness, but I think I did ok since they seem to be close to the hardness of my other S30V knife. I know they are far from perfect, and still need some work to be what I would call reasonably pretty and they have obvious faults, but I feel ok about them since the blades were both done on a bench grinder that went though hurricane Sandy. The bevels and finishing were done with a sanding belt that I ran on my bandsaw.
So finally, my question is related to grinding. I am not happy using the bench grinder as it has old 80 grit stones on it, has a lot of runout, and runs very fast. I am only marginally happier about the sanding belt+band saw option. I think because the belt width is a little small (can only fit a 1" belt on the bandsaw wheels), the belts seem to wear quickly, and the bandsaw doesn't leave me a ton of room to set up any kind of rest for maintaining any angles. I have been looking at purchasing/building either an actual belt sander like a KMG, or something like a Tormek. I can't really afford both, and I was wondering what would be more flexible and get me more mileage. The way I see it, the advantages to the belt sander are that it's easy to switch abrasives, and provides for a number of different grinds depending on platens/wheels/slack belt. The Tormek looks like it might give me more repeatable results, and the wheel would last considerably longer than the belts.
Anyway, I will leave you with a few pictures of my knives, any help and/or criticisms are appreciated. Thanks for looking!
y3mPWzrkkLyV4Op9ULafUR0KHyeSuqXTq9L5_hriud8LaBVuERK_c6TOdWmpv9MCJYAVfIQ0L4hloVvVdK_s4yUbWYOGc2i_II7s_KVNCf0o6VjJ_HlluvRoRiqyJB1peY4yes_KRDkf7PWSi_J6z_PGuAFkiDNOUBL9GzeUW3Bo6I
y3mXG7JVOPFkKuyso7bpykshh60ihQEtcLj29EgaGneYGzyfUK-csN1qm4wXwox5UrZb4yJ8v43ZpHXN1YVJBLhCGi60VF2FsQTEKi_MGXUCJJ0xzTiYbOsJTF7rA3dS7ttRW_T24bIjqvvla4PCM90QT0aCjl4sUVNn7LIKZWivv0
y3mAHUM6cstWor3I6adfnbERJIyiNlCTxDTyF9cOptQA38xhQxgBRfwu7zJSWZPJ9zIqJJuV-R35DzXgqsI8XPS3jxD_2PE7iZbRw2xOLrAmx12YSFEVUM0yU5s5x_q3PF7c-YVARTdj1E847k4JBpelhNoCvXc-0EZ5bJCURkQmHE
y3mvJuIzyCQ_3HS-KxRW4PSpn79mzCOfbOkdQaiDs-cQR9R7pGMLmgvDJf_wNhtow8wM5fg-JJoJRgENQamlufwP1Z6QzCCKPv-qEDtxyEEhhsBORF-45QqB7H5TpQHDt4_YNpEXCn1XliinYXHEsWK9b9nuAk-0o7NX-Fl-xu6ucI
y3mb6s9UAwYV45erBOwYGBIlCs0Zsbas56qWzuo-eZGRQg0yUOs93u9E3sEdMaC_WsFvcZvHCsoP4RpUaHym-TG4b9Qo1EUSRSfbvhWB1CmVX895SGPRzIBt4LxrUgmcKm8iuoZjdQ-DBaI-V9kBdX26oohG5a_2lQ08bc8t3JqyXI
