... But, the plain jane models in the titanium cases are a bit, well....boring to me.
Actually, they're handle slabs, not cases (it's a knife, not a watch
(but I'm not spending $500+, so they're out.
Not yet you're not...just wait.
Still, a knife is by its very nature a utilitatian object first, so ruggedness is important, but I don't want a plastic coated Spyderco, I know that.
FYI, depending on the model, the handle is either Fiber Reinforced Nylon (FRN), or metal, or some other composite like G-10; I don't believe Spyderco makes anything with a plastic coating. I think something like the Spyderco Lum Chinese is as attractive a knife as anything out there.
Mayo's are great but a bit pricey for my first good knife, and I'm not sure I like the Swiss Cheese styling.
The wonderful thing about customs is that you could order one without the holes, if everything else about the knife really trips your trigger.
I think a William Henry carbon fiber might do the trick.
I hear good things about the WHs. There's actually a nice-looking Bailey Bradshaw semi-custom for sale quite reasonably in the For Sale
roduction Knives section of this website (not by me). It's a similar type of knife, and the 3V steel its made of is top-notch.
Can someone please tell me about the pattern on the damascus steel blades? Is the pattern chemical, naural, etched, or what? Will that pattern wear off when you sharpen it? How well does damascus hold up for every day use?
Damascus is made of layers of different types of steel. When the blade is etched, the different steels react differently to the etchant, resulting in the layered appearance. Damascus will show scratches just like any steel, but it holds up fine to everyday use. It is theoretically possible for the welds between the different layers to weaken the steel. This won't be a problem with properly made damascus. The pattern will not wear off with sharpening. If you want to see some incredible examples of what is possible with damascus, check out Ed Caffrey's website at
www.caffreyknives.com. Mr. Caffrey is also making folders now, if his designs interest you.
Hope some of this is helpful to you. I hope my hints about knife vocabulary don't offend.
