So, you keep the stone on the table? And you use some lubrication like water?
How are you holding the knife?
One hand (and all fingers) on the handle one hand (and two-three fingers) on the blade?
Does the knife wobble a lot as you're sharpening (left/right and up/down)?
How did you find the angle, permanent marker trick? Balance the edge on the stone (push with fingertip to balance)?
How hard are you pushing ? If you put stone on a scale and try sharpening how many pounds does it register?
In the picture the tip area looks fairly even/consistent,
so you're probably holding angle correctly,
which means your stone might be loaded with metal and need cleaning (soap and brush, or oil and brush, or run in dishwasher)
or worn/glazed and need conditioning (raise a little slurry by scratching with a nail, or short rub on slightly coarser sandpaper )
but pictures can be tricky and maybe it is your technique
30 minutes sounds like a lot time , esp for the tip only, but I've been there about a year ago, when you go it alone, nobody to watch you and point out stuff
I would do a lot of wobbling left to right, so half the blade wasn't making contact
I would also flex/bend the blade (paring knife) , so "half" the blade wasn't making contact
then I'd also do a lot of up/down wobbling, so the angle would change from too low to too high
most frequently I'd be lowering the angle instead of sharpening at existing angle -- unintentional regrind -- this is slow
gripping the handle too hard so the fingers/wrist would start to feel it
I also didn't focus in raising a giant burr in the beginning,
instead I tried and struggled with the edge reflection method
