Hey Guys,
I'm new to this forum, any knife forum for that matter, and I'm having trouble right from the jump. I have read a lot of the archived posts, and the sticky posted by Mag_G in particular. I started with a CKRT EDC, and followed the directions in the sticky, on how to properly apex my edge. I'm working with a basic Lansky guided sharpening system, with the coarse, medium, and fine stones. I have sharpened knives on the Worksharp, grinder, and by hand, but none were worth anything when I finished, so I'm starting at the beginning and trying to learn the proper method. That said, I spent a while with the coarse stone, maybe an hour, and took my time trying to correct the edge and properly apex it. I'm sure the scratches mentioned in the sticky were uniform, and I tried to get a good burr, but it really didn't feel as pronounced as I thought it should. So I tried using the marker method, I read about here, to be sure the edge was uniform. After using the marker, and checking every couple of times with a magnifying glass and bright headlamp, I repeated the process on the opposite side. I went from the coarse to fine stones using this same process, and finished with a strop on a piece of 5000 grit sanding sheet. I have never stropped a knife, but I followed the illustrations in a post I found on here. I only did it a few times, to try to remove the micro-burr, because I wasn't really sure what I was doing. After all that, I tried testing the sharpness of the edge by feel, and cutting a piece of paper, and found it wouldn't cut at all. Disheartened that the last couple hours was spent in vain, I grabbed a double sided Smith's field sharpener, with a carbide angled coarse side and ceramic rod fine side. I ran the knife through the fine side while watching tv, for about 10-15 mins, and it is extremely sharp now. What did I do wrong in the stone sharpening process? I have some, what I think are good knives, K-bars and Cold Steel knives, so I need to know what I'm doing wrong on my practice knives before I ruin my good knives. If I don't have the talent you gentlemen have, for professionally / correctly sharpening them, I will concede; but I know almost nothing when it comes to the level the guys here sharpen at, so I would greatly appreciate any guidance that anyone may have for me. I would welcome the opportunity to try ay recommended techniques, and report back the results. Sorry for anyone that actually reads all this, but I wanted to give as much info in the OP as may be required. Thank you, in advance.
