- Jun 4, 2008
Hi there, new member here working on my first serious blade smiting project. I'm hoping someone can help me with a bowie that I'm working on. I'm a fairly competent blacksmith and machinist, so shaping the blade from the rough blank I've made. However after I've worked it in the forge, I'll have to re-harden and temper the steel, something I've never done. My first question is how do I tell what type of steel it is? I am hoping to use the oil bath method to harden it as I know that it was oil hardened originally, but I'm not sure what type of steel and thus if there's a specific oil I need to use. My second question is what temperature do I have to heat the metal to temper it correctly for optimal hardness? From what I've read, a conventional oven around 425F is what I should do, but I don't know for how long or if that is also dependent on the steel type, hardening method, etc.
