Newbie questions
I have played around a little with knife making. I have made my first knife by filing the grinds and shaping with a file, and than heat treating in a make shift grill/hair drier. I have also made a couple blades with a craftsman belt sander. All blades were made with O1 steel. I would like to get a little more serious. What type of grinder and heat treat oven should I purchase, and what is it going to cost me? I just want to play around. Any other ideas would be great.
The first thing anyone is going to say is learn to use the search function. It's kind of buggy sometimes but you should eventually be able to get a lot of info that way.
I think you'll also find a lot of controversy when it comes to your question because there are so many variables. If you want to spend less than $350 there is a grizzly 2x72 belt grinder that's pretty good for starting out. There is another comparable one that's a little more but I don't remember the manufacturer. The really nice ones will cost $1000 plus, and that's BEFORE you buy a motor. You can spend $2000 pretty quickly on a professional grinder setup. The heat treat ovens work pretty much the same way. I first did my heat treating with a cutting torch. I can't refer you to any manufacturers for the oven because I don't have one but for grinders look at Grizzly, Bader, KMG. Others will probably give you more info to research.
-Jeramy
Do the grinders like Grizzly, Bader, KMG have multi sppeds? When I use my Craftman it is too fast, and hard to controll.
Get a variable speed unit (or change the motor).
I would also advise you to get some more experience with blade making.Go to some makers shops,attend a few hammer-ins,etc.That way you will get a feel for what works and what doesn't.Basically you are saying you had a couple of good swims in a pool and are now ready for the English channel.There are a few stages between a Craftsman sander and BBQ forge and buying a Bader and a Paragon.As to the cost,a good grinder and oven will cost several thousand dollars.
Grizzly's grinder- the cheap one- is a single speed. I haven't found any way to change that without altering the unit. Some guys have attached a pulley on the wheel side and connected that to a variable speed motor, but then you're adding at least a couple hundred$$ to your cheap grinder. The above advice about trying things out in other's shops would probably be a great way to get a clearer idea of what you want and how deep you want to get.
I've also heard a lot of people say that they started out using the small bench grinders. I made quite a few blades on a 1x24" belt sander, but it wasn't fun. Probably would have been smarter just to get good at filing them, and then using the sander for finishing work. :p
