Hi all, I have just received my first Chris Reeve knife and I am of course thrilled . Its a brand new small Sebenza with silver thumb stud and spacer. I am obviously a newbie and I just wanted to check some things with you more experienced Sebenza owners. Please bare with me and my newbie questions and also that English is not my native language:
(1) As it is brand new I found it a little bit hard to open and close but I guess this is normal with a new one from what I have read here on the forum. After half an hour my thumb is rather sore. If I disengage the frame lock, the blade moves smoothly so the issue seems to come from the pressure of the frame lock.
(2) After playing with it for like half an hour and dissembled it in order to remove the lanyard and pin and didnt really check if the washers were put in again, turned the same way. Is this important on a new knife? (as I think this matter more on a broken in one ..).
(3) After putting it together I took a close look at it and saw that both washers can be seen when the blade is open if I look into the base if the blade in gap at the frame lock. Is this normal?
(4) When the blade opens, it runs smoothly until the frame lock pre-engages a little like 2-3 cm before it locks in the open position. It seems as this happens as the base of blade turns and passes the little bump on the inside of the frame lock (which I think is there to ensure the closed position). Is this normal?
Again, sorry for these newbie thoughts but they seem to disturb my peace of mind when it comes to this awesome knife.
Best regards from Sweden /Bo
