Thanks guys. pretty much what I expected, just depends on how sharp you like your blade! Yes, I have watched the videos (once) the Sharpmaker is in route and I will be watching them again, guess it will just take some experimenting!
Ditto for me. I do the exact same thing(s) .I test the edge first.
If it's sharp enough for me, I leave it alone.
If not, I sharpen it. At what point in the progression from coarse to fine I start with depends upon how much out of sharp I deem it to be.
I assume you have at least watched Spyderco's SM sharpening video.
Watch jdavis' vid on using the flats of the SM rods -
[video=youtube;-MHe_8wTHmg]https://www.youtube.com/watch?v=-MHe_8wTHmg[/video]
I do this especially when working the tip to prevent rounding it off.
I like to put my own edge on. It's fun and easy, and I get the exact edge I want. And even though it doesn't matter too much, I can't stand uneven bevels.
This is a fantastic video. It changed the way I use the sharpmaker. I use a modified version of what he does now (and have been for several years). It really speeds up the process on a duller blade, as compared to "one stroke left, one stroke right". It's almost like the scrubbing technique one uses on a horizontal stone. Just applied vertically.
Regarding hitting the tip and not rounding it: If you have a tendency to slip off the bottom of the rod near the tip, I've found a technique that helps me. I aim to touch the base of the sharpmaker about 1/2" back from the tip. So the last 1/2" of the blade actually touches the black plastic base. What about the rest of the blade up to the tip ? It never gets touched right? Well, all you have to do is draw the blade towards you, maintaining sideways pressure against the rod, and stop with the tip is in the middle of the rod. That way you grind the whole way to the tip, but you have more control because part of the blade is (lightly) resting on the sharpmaker base. Just a little technique I use sometimes.
Brian.
