When new to knives people get new knives, one of their first thoughts is going to be - How do I keep my knife sharp. For what it's worth here's my .02¢.
There are a lot of threads and posts in this sub-forum about angles - 20º, 30º, etc.. Too many people worry about getting that
exact angle when all they need is to be
close to that angle and most importantly be
consistent in the angle they hold their blades at from sharpening to sharpening.
Their next worry is what to use to sharpen their knives. I have been hand sharpening for years and have settled on stones mostly like the ones show in the picture below. Norton India coarse/fine, aluminum oxide stones and Arkansas stones. One other stone that I also use is a Norton Crystolon stone shown in the second picture.
Perhaps one of the easiest ways to get into sharpening is to use a simple rod system. Most of these systems have predrilled holes or slots to hold various rods and sharpeners at a consistent angle. Here are two systems that I have. The Lansky system holds rods at 20º and 25º while the slots of the Case system hold a sharpener at 20º. Both systems are very easy to use. Just follow the directions that come with the systems. A plus for the Case system is that you can use diamond stones from various manufactures.
A heads up - you may need to lightly and carefully sand the holes or slots to fit the rods or sharpeners to their holders.
EDIT: Adding this picture of a Spyderco Sharpmake to say it would be a great addition as a "rod system" but it is perhaps a bit expensive for just starting out. As stated below, the Lansky rod system next to the Sharpmaker will do just fine to get a beginner started.
OK!! This has been kinda clumsily written but I hope this helps some of you guys. I think the easiest way for a new sharpener to get some sort of satisfaction when they first start sharpening is to use a round-rod system such as the Lansky system shown above.
Of course everyone can start out using diamond sharpeners but those are a bit expensive for someone just starting out sharpening knives. Here are a few of the simpler diamond sharpeners to use.
Whatever you new sharpeners decide to use keep it simple and be patient.
