I made about a dozen knives in 2018 using a HF 1x30. A few weeks ago I moved up to a 2x72 grinder with adjustable speed, and 2hp motor (3600 rpm/4" drive wheel). I've got a flat platen, a contact wheel and a tool rest. And 1084, 1095 and aeb-l for steel.
I've been reading old threads regarding belts, but I'm still curious about a couple of things I haven't seen addressed anywhere.
Let's say I've cut out a rough blank, and I'm going to start by profiling. This would be done with a low grit (36 or 60) ceramic belt, at high speed and medium/high pressure?
When I'm done and I want to start grinding my initial bevels, probably still using a 60 or 120 grit ceramic? And pretty high speed and pressure?
Where in the process would a zirconia or ao/zirc belt be used? Are they used for lower speed or pressure grinding than ceramics?
And finally, if I go to an AO or Gator belt for finishing, what sort of speeds are they supposed to be run at?
Thanks!
Thanks!
