Archer Here
- Nov 2, 2008
Newest Batch of Ordered Blades Ready to be Crafted!
You are also looking at the next SBG Exclusive blade in our Doomsday Line, designed by Jason Woodard. So stay tuned for that release! Thank you customers for your continued business, from Scorpion Swords & Knives!
A Glimpse of a Recent Custom Creation:
This particular customer wanted a customized version of the Prince Nauada Hellboy II Purgatory Spear Knife. Hellboy II was a highly ranked supernatural superhero film. Turned out nice! We received a lot of responses on this one, so we’ll probably add it to the website in the near future.
THIS WEEK’S FEATURED DURABILITY VIDEO: Doomsday #2 - Dark Ninjato EXTREME Durability Tests
Part of the Doomsday Line. Exclusively offered only at the SBG on-line store. Watch professional reviewer Jason Woodard do EXTREME durability tests, slicing through Tatami Mats and jugs, chopping and stabbing on plywood, 55 Gallon Steel Drum, Concrete Blocks, Solid Granite, Striking against a Metal Pole, Bashing it against a Wall Hanger Sword (Steel vs. Steel) and more!
SBG FEATURED BLADE OF THE WEEK: Tactical Leaf Blade
Fully functional tactical version of the ancient and effective cut and thrust Leaf blade shortsword. Leaf blade shaped swords are one of the earliest types of blade - first made in bronze and then later iron. Used as a backup weapon by the ancient Greeks, Spartans and Celts. The classic design is perfectly balanced between cutting, thrusting and hacking. Professional reviewer Jason Woodard completed extreme durability tests from Slicing Multiple Jugs, to Chopping a Tree, Stabbing into a Metal Trash Can, Striking against a Metal Pole, Chopping on Hard 4x4 Pressure Treated Wood as well as Solid Composite Deck, Striking against a 55 Gallon Steel Drum, Chopping CONCRETE, and then Striking against SOLID GRANITE!
THIS WEEK’S FEATURED BLADES – Tactical Ginunting Sword
The Ginunting goes way back in history and to date is a favorite by the Philippines marines. They used this short and versatile weapon to win combats. Able to take away any body part it is aimed at. The downward curving blade makes it the perfect tool/weapon for close encounters as well as going through thick jungles of the Philippines. Useful for clearing brush, cutting wood and is a great slaughtering tool for hunting. The handle is extremely comfortable for use, making it the most versatile Filipino weapon ever! In English “ginunting” means “cut out”, which is exactly what it does. It will cut through anything and everything which is why the Filipino warriors chose them.
Shop Details:
1095 High Carbon Steel. Steel is Heat Hardened & quenched in oil. Heat Tempered @ 500 degrees for 2 hours, and letting it air cool.
Measurements:
Total Length = 26 ½ “
Blade Length = 19 “
Blade Width = 1 ½ “
Blade Thickness = 3/16 “
Handle Length = 7 ½ “
Handle Width = 1 ”
Handle: Black Linen Micarta
Weight = 2 lbs
POB = 2” from Handle
Shop Details:
Measurements:
Blade Length = 19 “
Blade Width = 1 ½ “
Handle Width = 1 ”
Weight = 2 lbs
