- Oct 10, 2002
My newest completed project (yes, there are many more in various stages lying around, or in my head) is a knife holder to be used for working on knives. I had seen other designs at Blade and other knife shows, but wated something a little different. I had most of the parts/materials lying around, so I designed it (as I was making it) and finished it today. It is made to fit the thickest handles (Magnum Fusions) or the thinnest blades and has full length rubber pads to protect and grip the knife. It is 12" long on the inside, but could put longer knives in it as it is built stout and they could just hang out. The base swivels so you can hang it out over the side of a bench and bring it back in so it is out of the way. The red square blade holder rotates 360 degrees so you can have the blade or handle at any angle to work on it, just pull the long aluminum lever on the side down, rotate to where you want, then push it back up to lock it. The one picture shows me using the Magnum sharpener on a SHBM.
