I promised Titan I would do a mini review of the G-45 as soon as it came. Here are my observations:
The G-45 is 7 3/4 inches long in sheath. The knife is 7 inches. The steel is 1/8 inch 1095. The sheath has an adjustable paracord. Both Kytdex sheath and paracord are an unobtrusive brown. The sheath is much smaller than the sheath which comes with the Stiff KISS. The sheath is 1 5/16 inches wides and about 4 inches long. The retention is excellent with a strong, but reasonable pull required to release the knife. The knife has a great belly and nice tip and has about 2 3/4 inches of cutting edge. This blade really contrasts with the Stiff KISS, which is flat tanto style. The blade was reasonably sharp, but not shavin sharp. The Stiff KISS came shavin sharp. I'll have to put this one on the Sharpmaker to get it to where I like it. The paracord on the G-45 is much softer and more comfortable than the paracord on the Stiff KISS. The same softer paracord is wrapped on the handle and provides a nice grip. The handle is approximately 3 3/4 inches long with paracord wrap on the middle 3 inches. The handle flares out from 1/2 inch in the middle of the knife to 1 inch at the butt end with a nice flair out on the last 1/2 inch or so which helps retention and pull. There is a little circled out area with a hole between the handle and the blade which tends to keep your finger off the blade.
This knife is very comfortable to wear either inside shirt or outside. It sits very comfortably and you can easily forget it is there. I find it much more comfortable than my Stiff KISS and quite a bit less obvious.
I like it a lot. Unfortunately, so does the other knife nut in the family.
Now, I will have to order another one. I made the mistake of giving my daughter the choice between Stiff KISS and G-45. She picked the G-45. That probably says as much as all the above verbage.
Ok, Titan that's it, as promised.
