Archer Here
- Nov 2, 2008
Announcements & Latest Scorpion News:
The Doomsday Badland Katana II durability test video by Jason is nearing completion, so we will be releasing that soon!
Be on the lookout for our release of the new Doomsday Dark Ningato II Sword!
Due to this steady increase in order volume, we have had to temporarily put a halt on all custom orders except for slight modifications to our existing designs. Also, you may also have noticed that we have had to flag some of our more labor intensive blades to “Currently Unavailable” on our website. This is only temporary to help get our shop order list and wait times down to a more manageable level.
Here is Our Next Batch of Ordered Blades Ready to be Crafted!
Our BIGGEST batch this year! Some of you will definitely be ready for the Zombie Apocalypse! You are also looking at the new Doomsday Daywalker II and the Doomsday Viking Sword - new designs by professional designer Jason Woodard! Thank you customers for your continued business, from Scorpion Swords & Knives!
THIS WEEK’S FEATURED DURABILITY VIDEO: Doomsday Machete EXTREME Durability Tests:
Completed by professional reviewer Jason Woodard. Tests from Chopping Trees and Large Logs, Striking and Stabbing a 55 Gallon Steel Drum. Striking against a Metal Pole, Concrete, and SOLID GRANITE. Steel vs. Steel Sword Tests! Striking against a known machete from another company that has been out there for years, and it completely destroyed the edge of the other sword. This Machete did not break and passed all tests, leaving only minor edge damage when it was struck against granite, something you should never be able to do.
SBG FEATURED BLADE OF THE WEEK: Tactical Wakizashi
Monotempered Ultra Durable Tactical One Handed Wakizashi. Based on the traditional Japanese single handed Wakizashi, it is perfect for close in fighting with enough mass to deliver a shearing cut and an acute tip for deep penetration in the thrust. Combined with the Tactical Ko Katana, it can also be dual wielded for maximum effect and intimidation factor. Professional reviewer Jason Woodard completed extreme durability tests from Slicing Multiple Jugs, to Chopping a Tree, Stabbing into a Metal Trash Can, Striking against a Metal Pole, Chopping on Hard 4x4 Pressure Treated Wood as well as Solid Composite Deck, Striking against a 55 Gallon Steel Drum, Chopping CONCRETE, and then Striking against SOLID GRANITE!
THIS WEEK’S FEATURED BLADES – Commando Jungle Knife
One of our featured swords this week: Thought we’d share some pictures of it.
Commando Jungle Knife:
Full tang heat treated blade is designed for usage under extreme conditions and is virtually INDESTRUCTIBLE. Extreme Durability Test Video showing this thing chop through Concrete Blocks, even Antler. Then still had an edge to slice through multiple jugs easily.
Shop Details:
1095 High Carbon Steel. Steel is Heat Hardened & quenched. Heat Tempered @ 500 degrees for 2 hours, and letting it air cool.
Measurements:
Total Length = 19 ¼ "
Blade Length = 13 ¾ "
Blade Width = 2 3/8 "
Blade Thickness = 3/16 "
Handle Length = 5 ½ "
Handle Width = 1 ½ "
Handle: Black Linen Micarta
Weight = 1.9 lb
POB = 3” from handle
Shop Details:
Measurements:
Weight = 1.9 lb
