Nice surprise: Benchmade 14210 (HK29FDP)
Picked this up literally on a whim; stumbled across it browsing a dealer's site. I had no idea it was even out there. I've always been a fan of Snody's designs; but the pocketable dimensions and AXIS lock made it a nearly perfect candidate for EDC evaluation.
The pictures on some dealers site make it look considerably less attractive than it is in person. (IMHO.) I honestly thought the blade looked kind of dopey viewed directly from the side in 2D. It was much to my enjoyment then, to find that the swedge and gentle recurve are actually quite pleasing once it's in front of you.
The 2.95" blade is 154CM, served up nice and sharp. Good grind lines with a nearly polished edge. The blade finish is a nice, almost a satin machine-like finish. The HK logo is subtle enough, and the only other text on the blade is a small "154CM" and "USA" on the reverse.
The handle is grooved G-10. It's milled along the horizontal of the handle (vertical if it's clipped in your pocket...) and while textured, it's not aggressive to the point where it's going to eat up pocket lips or your hands. Nicely done.
The full liners are swiss-cheesed, presumably for weight savings, and remind me of the liners in my 806D2. (Built for strength with a nod to heft.) Phosphor bronze washers are used, and the action is silky smooth.
The AXIS lock is of course, a central feature and as usual, works great. Nice tight lock-up yielding no perceptible blade play. It took about a dozen opening and closings before the lockbar would slide smoothly across the liners, which had me a bit concerned at first. The opposite side would bind on the liner and make it tough to release the lock one handed (with one thumb anyway) but it smoothed out almost immediately and has turned into a real gem.
The 'split arrow' clip is tip up only, and can be swapped to either side of the handle. Those who hate clips will probably still yank this one off, but it's not too terribly bad in the hand.
Other random thoughts:
-The steep thumb ramp provides a secure purchase for the thumb. This, combined with the natural choil of the handle shape, makes for a very secure grasp.
-The handle is long-ish for the blade size and provides a "bigger" knife feel. Users who have larger hands, but prefer ~3" blades will probably like the grip.
-Handle thickness is right about 3/8". Robust size without being too chunky.
-Twin backspacer posts are tapered and turned pieces that make for a nice touch. They could've cheaped out and used some simple round spacers, but these are cool.
Two things I'm not so sure about:
-Dual pivot screw heads. They stick out above the G-10 a little further than I'd like, but they don't seem like a big deal other than slightly odd in my mind.
-Single exposed screw head at the stop pin on one side of the handle. Seems like this could have been countersunk like the backspacer post screws. But agin, cosmetic I guess.
Functionally, it seems typical Benchmade. Strong, smooth, and reliable. Granted, it's life with me will be pretty mundane. Some mail, the odd bit of rope or string, kid's toy packaging, and cardboard boxes. I expect it will perform well, but time will ultimately tell.
Just based on these initial observations and playing around with it, I'd not hesistate to recommend picking one up. Especially if you were/are a 705 fan and like Snody's designs. It's a pretty trick smaller knife and should be considered for anyone's EDC list at this particular price point.
Looks like it might make a nice substitute for the Benchmade 707 Sequel, for people who want a smallish BM but don't cary for the 707's aluminum-with-G10-inserts handle.
I'm glad you posted this. The thickness was a question I had but coincidentally I did order one of these early this morning. Actually I've been trying to find one for some time and ordered one earlier only to be told it was a pre order so it got cancelled. Then in my email this morning a good friend sent me a link and I finally found them at Newgraham.com and jumped on it when I saw it.
I've had the BM420 Resistor also designed by Snody and it was a great knife but bigger than I usally lean towards for my everyday carry knives. It was also a thick knife. I really like knives about the size of the Calypso Jr and on the large end maybe the Spyderco Ocelot for my EDC knives. Anything bigger than that I just don't seem to enjoy carrying everyday. Long thick knives are only good in the hand but in the pocket I don't want to know its there until I need it.
This little HK 14210 struck me right away as the 'mini 420' I have been waiting for. Of course the other thing that stood out to me was the fact that this knife is a "Rave" waiting to happen. I will most likely have it Waved and working great by mid afternoon the day it arrives. I'm so confident I'm going to love it that I already sold my 420 in anticipation of this ones arrival.
Thanks for the review. Good coverage on the details the manufacturer leaves out.
STR
I just got my 14210 this morning in the mail. Initial impressions are that it is really a great folder. Smallish but I knew that going in. It is around the same size as the Calypso Jr. which is about perfect for EDC. The only thing I see that most people into so called "tactical" knives are going to find to fault the knife is that there is no lanyard hole. I noticed this on the bigger HK model also. Kind of odd that a HK would not have a lanyard to me since the BenchMade 420 Resistor does. But other than this one thing the knife is flawless in function. Fit and finish is excellent and the lock up rock solid as is expected with an axis lock. Of course the opening and closing is silky smooth like all the great BMs I've had in the past.
STR
Lanyard hole. Good call STR. I really like having one on a tip-up folder and it's absence on this model is kind of a bummer.
Still, an excellent smaller knife overall.
Its a lot smaller than the Ares though.
Big Jim I almost edited that when I put it there and then thought I'd sit back and wait and see if anyone else caught it. Good to see someone else is awake around here. :D
USAFSP said:
Looks like they redesigned the Aries.
Really? I don't see it.
Actually, it's a Mike Snody design, and the Ares was an Allen Elishewitz design.
Benchmade got the designs from custom makers on both, so I don't think it's a true re-design like say, 705 to 707.
Plus the Ares was larger, and had a spear point blade, as well as contoured or layered handles.
One thing they definitely have in common is quality...both are very nice!
That's such a great looking knife.
The liners look nice and thick like the old 705. Is this the case?
I really want one now but of course everywhere I look they are sold out. :D
How is the blade size compared to the 705? I would like a blade that is larger from the edge to the spine than the 705 was.
I really want to purchase one of these in plain edge. They seem to be sold out just about everywhere. Is this the case?
Anyone know where to get one?
I agree with Firebat. The 2D pictures don't do this knife justice. Once I handled one I had to have it. Yes the liners are thick.
