NIce wood, easily worked
Here is the deal, i want to carve two interlinked hearts for my significant other, but i wanted to pick a nice type of wood.
My question is what would be a nice piece to order that would be easily hand carved using a knife. outline will be worked with a beltsander.
looking for something in the 30$ range.
thanks guys.
X2 for Cocobolo, dense but waxy which makes it good to carve. You could also think of walnut as well, cheep and plentifull and relatively soft.
i actually hadnt thought about walnut...any affordable sources you guys normally use?
thanks for the input guys!
i might order one of each and do something different with the other piece.
so i thinkim going to end up doing just a solid heart and make it a necklace...the interlocked thing is gonna be....challenging. to say the least lol
and if able to pull it off, maybe earrings...thought idk if i can get them both matching perfectly.
this will be my first wood carving venture. im open minded and generally good with my hands but i dont wanna get in over my head either.
also looking into making a jewelry box.
to be honest im a bit set on cocobolo as it really is one of my favorite types of wood because of the colors and the natural sheen it has due to its high oil content.
Amboyna Burl... maybe a stabilized piece.
As for a task being difficult... isn't that really just an excuse to expand your tool collection? Sure it is.
except im on a college budget. lol
this will be done mostly by hand with a small fixed blade ( blade is about an inch and a half ish?) so it will work well i think.
i will have access to some tools but only to do the initial cutting from the plank. im hoping to do most by hand.
Im thinking a solis heart shape (rounded of course) then drilling two diagonal holes that meet inside so i can string a chain through it.
finishing it with sandpaper and sealing it with shellac and then some sort of varnish.
If you have a cabinet shop anywhere around you stop by and see what they have as far as scrap pieces. They may just give them to you. Most likely won't be cocobolo, but you never know what they do have.
Paul
Since it is for a necklace, maybe a pinkish or reddish wood like pink ivory from Africa (Berchimia zeyheri) or Madagascar Palissandre another nice purple brown to reddish wood)or one with pink or red streaks in it like box elder burl has sometimes. If you can find any locals who turn wood for bowls and such they might be likely to have some scraps for free or cheap.
Exotic hardwoods are pretty, but some can cause contact dermatitis, not something that would be a good feature in a necklace. Google "toxic woods" and a few resources should come up. If this is your first ever carving, I would suggest starting with an "easy" wood like basswood, another option, maple would be a little harder to carve but is pretty non-allergenic
Mahoney is right on about the contact dermatitis. I read in a book (Know Your Woods) that cocobola is in the same family as poison ivy if I remember correctly. With that said, I do get some contact dermatitis if I handle cocobola too much.
I've gotten a few walnut and maple boards at a recycled building supply center. I ended up with a couple of 6" x 36" x 3/4" for about $20. I made a walnut base for my sharpening stones, a couple of maple sling shots, and couple of small cutting boards.
You might check with some flooring companies, they may have some scrap from a job. I've seen a lot of different types of flooring, you could probably find some walnut or maple, Sometimes you can get of buy a small piece of the flooring so you can see how it looks in your house, it may be enough for your project.
I made a tear drop shaped key chain out of manzanita (dark red) with an inlaid cross out of maple. I gave it to my wife and she has had it on her key ring at least as long as we have been married (28 years). It has held up better than I expected. The polyurethane varnish is a little bit chipped and dinged up from the keys. The manzanita was a from a branch i cut when I was camping (northern California).
Ric
