The Tanto is my best seller in the Nighthawk line. (3 to 1 over the others.) The feedback That I have gotten from my customers is all positive. The tanto point appears stronger than the point on the regular Nighthawk and that makes users lean toward this model. Also, while I am not particularly fond of that style of blade, there are a lot of knife users who are.
The Nighthawk, in general, is a great knife. I have seen them in the factory before the handles were shot on and the tang structure and size makes it a VERY strong knife. The tanto point, with its particular geometry, makes it even tougher. This model is a very good choice for a field/survival knife. Great for digging and scratching through the dirt for whatever reason, and that tanto point isn't likely to break. This thing is really like a prybar with a good sharp edge.
The grind appears to be more on a chopping angle than a "shaving" angle, which goes along with the theme of the blade. The wider angle will hold longer than a fine angle and won't require touch up as often. The down side is for those who like a really sharp edge. This knife just doesn't have that. Of course, that could be remedied by a good sharpener. The serrations on this knife are really good too. Enough of the blade is serrated to make it work on line and webbing, etc. Good job there.
Lanyard hole. By all means, PLEASE!!! I have talked to Navy Seals who say that they would buy this knife if it had a lanyard hole, and the type of knife it is, it seems that the hole should be there.
Isn't it amazing how 2 cents worth of opinion takes up a quarter's worth of paper???
Please excuse the crayon. They won't let us have anything sharp in here.
wrightknife@ixpres.com
