My childhood friend (a year younger than myself) and I went to Wal*Mart on a mission to replace the crappy Husky folder that he recently lost- it was his workplace tool and he needed a new one. So we looked at the meager knife display, I asked to see the Native, which the guy flipped open in a way that I almost got turned into a throwing knife target, was very impressed, tried to sell my friend on it, but he had his eyes on fixed blades. I pointed out a 110 and told him that it was just like a fixed blade but more convenient to carry. He persisted, and I figured that if he wanted one of their fixed blades, I would at least point him in the right direction and advise him against Gerber. Then it was down to a 119 and a Buck Nighthawk, which I had never seen/heard of. At first, I told him the 119 was a good choice- hey, it's a classic. But after handling both, I realized that the ergonomics of the Nighthawk blew the 119 away. They're really full and squishy I knew it was the standard Buck 420HC, but I judging from the construction, I think it can be a trusty companion for the better part of a lifetime, maybe more. So for $40 it was his. The guy behind the counter said he'd need to see ID to make sure I was over 18. Unless I was going to stand in front of him until the beginning of winter, I wasn't going to be 18. But the moron looked at my license, ignored the bright red "UNDER 18 UNTIL 12-01-2006" and rang up the knife. No loss for me! So tomorrow we're heading out to a big park (Bradley Palmer in Ipswich, MA) so we can enjoy a nice hike with some good knives. I'll be packing my Brian Goode fixed blade. I must also say that the Buck sheaths are very nice for the price, and I like the way they hang and hold the knife. It's also made in the US, which is a nice touch. I used a magnet to trace the tang, and it seems to be a full tang but I could be mistaken. I hope it is. Ah well, I'm very happy for the new couple.
You can just sharpen it on a sharpening stone, at a lower angle than usual. Be warned, it could take a while unless you have a coarse stone. I did mine before I had a good diamond stone, on an old two-sided Norton India stone; the coarse side cuts pretty fast.How do I thin the blade to reangle it, making it sharper?
So I would want to reduce the thickness of the side that is opposite of the sharp edge? And what's a good sharpening stone?
I think you are misunderstanding him. Think of the edge as a "V" all you want to do is turn a wide v into a thinner V (\/ into V)
Hope this helps
No, you think the EDGE of the blade. Why would you grind the spine??That's what I thought he meant. I'm supposed to thin the back of the blade?
No, you think the EDGE of the blade. Why would you grind the spine??![]()
What's a flat, and what's a benchstone?If you want to grind down the flats or reduce the primary grind by grinding against the spine that is perfectly fine but it will take a very long time on benchstones.
...you can sharpen at about ten degrees per side and then add a small bevel at about 15 degrees.
-Cliff
The flats are the sides of the blade, i.e. the part that's not the spine or the edge. A benchstone is a common sharpening stone that can sit on a work bench or table to sharpen a knife. There are other kinds of stones (i.e. slips) so they use names like "bench stone" to differentiate.What's a flat, and what's a benchstone?
The bevel is the shape of the edge, i.e. the "V" shape. There is a bevel ground in to each side of the bottom of the blade, a \ and a / bevel which together make a "V" shape."Per side" refers to each side of the "V", in other words you will sharpen one side of the "V", then flip the knife over and sharpen the other side. As to sharpening 10 degrees and adding a 15 degree bevel, I'll let Cliff expand on that because I didn't understand it either.What's a bevel, and what do you mean "per side"? It's a one edge blade, not a double edge. And should I sharpen it at 15 degrees or 10 degrees? You mention both.
A little off-topic, but:The guy behind the counter said he'd need to see ID to make sure I was over 18. Unless I was going to stand in front of him until the beginning of winter, I wasn't going to be 18. But the moron looked at my license, ignored the bright red "UNDER 18 UNTIL 12-01-2006" and rang up the knife.
