- Dec 28, 2010
Hi guys! I was wondering if anyone out there has experience in heat treating Niolox +? I've been testing stainless steels to sell along side o1. So the stock I've been trying to heat treat is 4.5mm thick and I'm using stainless foil wrap and using a plate quench setup consisting of two large aluminium plates bolted to a vertical woodworking vice. I'm also using compressed air. My issue is that I can't harden this stuff past 59 hrC. I've now tried various recipes all within the manufacturers specs and one that I was given by the steel stockists that was outside of the specs but they'd had good luck with. Everything brings it to 59 hrC.
The manufacturers say that this steel can also be oil quenched but I'd really rather not if at all avoidable.
Any advice would be greatly appreciated.
Cheers!
Ruaridh J Hunter
Cheers!
Ruaridh J Hunter
