- Oct 16, 2021
What's the best way to clean up this Nitro-V without doing harm to the finish or metal? I am prepared to dismantle it.....
Never thought of that.......try pencil eraser. ive cleaned many rusts spots off that way that weren't too bad...
Thats some odd corrosion. I have one of these drop knives produced by Millet. No issues with corrosion and I carry it several times a week. I did sharpen it down a little and put a silicone ring on the middle stand off so the blade won't hit it.
really nasty rust wont do anything too, but light spotting will remove and not too deep yet stuff will remove the top layers and then easy to clean off with flitz or whatever product one likes.Never thought of that.......
Great tip !
Thanks....really nasty rust wont do anything too, but light spotting will remove and not too deep yet stuff will remove the top layers and then easy to clean off with flitz or whatever product one likes.
The pics in the OP remind me a lot of the corrosion issues Kershaw had years ago with their bead-blasted stainless blades. Not so much about whether the steel is stainless or not, but more about the particular bead-blast finish creating microscopic voids or pits in the surface, which allows dirt & moisture to cling to the blade more tenaciously, creating corrosion issues otherwise not usually seen in stainless steel.
Looking at the composition of Nitro V steel, it compares pretty closely to some of the Sandvik stainless blades (like 14C28N) Kershaw originally had some trouble with. It was more an issue on Kershaw's blades in Sandvik 13C26 steel, with the 14C28N being an improvement over that, but still susceptible to some corrosion with that finish (see linked post below, from an older thread). And I'm not saying there's anything wrong with the steels themselves, as Sandvik made some very good stuff. But it's more about the nature of a bead-blast finish in particular on such steels. It's not limited to Kershaw, either - but unfortunately for them at the time, they got a lot more negative attention over those issues. Other bead-blasted blades from other mfrs. have also had such problems.
https://www.bladeforums.com/threads/if-only-kershaw-would-stop-bead-blasting.732848/post-8095221
