NMFBM or Anniversary SHBM? Discuss.
SpyderPhreak
Rocketman for hire
Platinum Member
If you had your choice of either a NMFBM or an Anniversary SHBM (similarly configured), which would you choose and why? Let's pretend the cost was exactly the same.
I'm asking because this is on my mind right now, and is a decision I see in my immediate future (and yes, I realize they wouldn't be the same cost, but pretend they were). TIA!
I had this very same dilemma, it turned out for me like this:
Looks (depends on your taste)
if you are going to the tropic, go for the thinner one. NMFBM
travel up north or down south, get the thicker. SHBM
Good luck...you wont go wrong!!!... I got the NMFBM, and I´m happy with it...but I´ll get the SHBM anyways.
I only recently got my hands on a NMFBM so we'll see when the ASHBM gets delivered.
Are you certain that the NMFBM is thinner? The ANSHBM is listed at 5/16"/ 0.3125". Isn't that almost the same as the NMFBM?
To me, the Mistress is iconic, better looking, and, at $487, a good value for a Busse. If I can sell some things to raise the scratch, I would order the ANSHBM.
NMFBM is the king.
My pinky finger hurts just looking at the anniversary mistress.
Thing is, it is a beautiful classic design but it is not as ergonomic as the later models. Maybe this is why the next series of Busse's following the originals were called "ergo".
NMFBM is just about perfect... an amazing chopper.
Just sayin...
I haven't used a SHBM, but the ASH had a similar handle that gave me a sore pinky when chopping. I sold the ASH.
My NMFBMLE with hand-shaped tiger linen micarta handles is a dream to use, with no "hot spots" after heavy use.
If you do go NMFBM, I definitely recommend hand shaped micarta. G-10 is a heavy brick, and machined handles tear up my soft lily-white chef hands.
Kdstrick, it's funny, but I began my post a couple of hours ago,before an interruption. I didn't see your post, and we had identicle sentiments on the handles
Yeah I like my pinkie. I am really on the fence about the SHBM. I really want one because they are available and the price is right. On the other hand the fusion handles are the best.
The original NMFBM was about .21 to .23 just a little less than a 1/4 of an inch. I also had a 5/16 and weight was a big difference in the two, I prefer one with a thinner blade but still strong enough to handle everything without blowing your shoulder out. I want a SHBM but when I saw the thinkness, it stopped the buying process for me.
Ha... glad I'm not the only one!
Pinky blisters are terrible....But I've never had one with a fusion handle (a blister).
Last night my bourbon addled brain read NMFBM, but thought NMFSH. :o
You are correct, of course. The first run NMFBM were thinner. However, they were not flat ground like the AnSHBM. They have a pretty robust full height convex, so that at half height, they are still pretty thick. The NMFBM may therefore have more metal and weight out in front of the handle than the AnSHBM. Jerry has commented on the excellent balance of the AnSHBM, so maybe blowing out your shoulder would not be a problem.
+1 Ergo handle all the way!
NMFBM is the king.
Just sayin...
The NMFBM is heavy enough for me and its .25" thick. 5/16" thick is problably gonna be too heavy for my purposes. Not gonna deter me from getting one though...
I really wished the ASHBM was under .22" thick, even emailed Garth about getting one with reduced stock thickness but apparently it cannot be done due to the machines that do the grinding.
I just wonder what the total weight will be at .31" thick, considering the proto at Blade 12' weighed 21 oz roughly at .25" thick. So maybe, say, 28 oz or so?
Just wish it was something I could actually rationalize carrying, at 28 oz. it's not something I'm going to want to have with me (especially considering it wouldn't add any utility over something like the 1311 at 19 oz.).
I am so stoked for the AnSHBM. My guess is that the balance point will be right at the Busse logo on the blade, as is the case with my NMFBM and B11. If the style of ffg of the NMFSH is any indication of the ffg AnSHBM, the 5/16" spine would come to a significantly thinner thickness behind the edge than the NMFBM, and allow for that optimal forward balance. I am actually more worried that it will be too thin than whether it will be too heavy. That's my speculation and I'm sticking to it! [until I get drunk and swayed by some better speculation :D]
The main thing, though, is that it will be super sick and I will probably have to hit up Joshua Tree the first weekend after receiving it. NorCal winter ain't gonna stop me from partying with my new SHBM!! :thumbup:
NMFBM is the king.
Just sayin...
++1:thumbup: Totally agree Kevin!!! NMFBM is just a Beast and at .250" it wields perfectly. I have had to original SHSH and SHBM and the hilt was just to tight for me as in not enough hand room. Oh I love the looks and if chopping was not the task at hand then OK. But chopping, give me the NMFBM.
...The first run NMFBM were thinner. However, they were not flat ground like the AnSHBM. They have a pretty robust full height convex, so that at half height, they are still pretty thick. The NMFBM may therefore have more metal and weight out in front of the handle than the AnSHBM. Jerry has commented on the excellent balance of the AnSHBM, so maybe blowing out your shoulder would not be a problem.
I think this could be very illuminating.
For example, the convex-ground skinny ASH1 (nominally .1875” thick) weighs within a half ounce of the full-flat-ground ASH1 LE (nominally .22” thick). If you use that differential, the weight for a full-flat-ground 5/16” NMFBM (which never existed) would be about the same as a convex-ground NMFBM at .2678” thick—in other words, somewhere between the original NMFBM and the NMFBM LE. This on a knife that has the same nominal blade size as the ASHBM.
If you then replace the fusion handle with the shorter SHBM handle and go a step further by skeletonizing the tang (per Jerry’s description), you would end up with a 5/16” thick, 11-plus-inch-blade knife that could weigh about the same as a standard 1/4” thick NMFBM.
I’m not saying this comparison will be spot-on accurate, but it certainly begins to illuminate the handling potential Jerry mentioned.
Also, as many others have said, I like the chopping comfort of the fusion handles compared with the old straights, but I'm interested to see what the new ASHBM handle feels like with the thicker, more contoured slabs. The extra slab thickness near the rear talon, combined with the wider 5/16" tang thickness, will be interesting to try, and depending on how the new contours affect grip, I'm reserving judgement until I have the ASHBM in hand. Of course, I'm sure my optimism is fueled by a desire to let myself fully fall in love with such a sexy new mistress. :D :thumbup:
Will,
You're just an old softy Bro and a bleeding romantic!!! "Of course, I'm sure my optimism is fueled by a desire to let myself fully fall in love with such a sexy new mistress.":D HA-HA....
