- Feb 3, 2009
Not available in Canada. Ridiculously expensive to order and ship from U.S. BUT, I noticed in the Sebenza FAQ that once upon a time before fluorinated grease, CRK packaged and sold a "pure Teflon" lube under their name which they recommended for Sebbies.
As it happens, I found a DuPont product called "Teflon Multi-Use Dry, Wax Lubricant". It is indicated for chains, garage doors, hinges, windows, bike parts, firearms, tools and more. Will not absorb dirt or grime.
Anyone have any experience with this or any other Teflon-based lube? Yes, I know that any good quality oil/grease/lube will do fine in a Sebenza. I'm not asking if you guys think I should use it or not. Just looking for anyone with knowledge of this type of lubricant.
ALSO, I'm curious about the use of mineral oil in Sebbies. Most say it's fine for folders, however, it totally seized up my mini Rittergrip only a couple days after application.
ONE MORE THING -- Is it recommended (by you users) to break the Sebenza down, clean then lubricate it, first thing upon receiving it? Or should the stiffness just be worked out through normal use?
