- May 14, 2001
There's been so much talk about welding without any flux recently that I decided to do a little experimenting today. I'm a bit "Old School" in that I was taught to weld with borax about forty years ago and am reluctant to give up the old ways. Today I tried welding with no flux what so ever. I started with a typical 20 layer billet of 1084 & 15N20 and spot welded the bars with my MIG. I then placed it in the forge with my usual six inch flame extending from the opening. After a short soak at welding temp, I did my usual light squeeze in the press and back into the forge for another soak. The second time I did my usual heavy squeeze in the press. In order to really test the welds I then did a "W" squeeze and drew the billet out and cut into six pieces. Without doing any grinding I stacked them and spot welded with the MIG. I wanted to see if leaving all of the scale on would make any difference. I then returned the billet to the forge for a ten minute soak at welding temp. The idea being that the oxygen free environment there would turn the scale back to steel. Here's the result:
Though it's a long way from a finished blade, so far I can't see any flaws. I guess that the process works.
Let me know if you've tried anything similar and what you think.
Gary
Gary
