No in the butchering game.
I butchered a bullock the other day with one of my NO’s, done it Territory style. He would have dressed around 1100 lbs, so he was a fair lump. The NO performed great and made easy work of it. I normally would have used a standard butchers skinner. Apart from the NO being a lot heavier it had a great feel to it. The handle covered in blood still had a good grip to it throughout the job. I never at any stage felt disadvantaged using it. A beast that size has a very thick hide so I gave it a couple of light steel’s, conventionally on both sides throughout to bring it back up to sharp.
Question…?
I have stoned the knife since, on the short side with the course stone, then finished off on both sides with a fine ceramic stone, the knife came up very sharp.. Will this method eventually turn it back into a conventual edge?. I have no problems with the edge as it is, but don’t know how to sharpen it properly. I use a local made sharpener called a “Bladesharpener” works like a Lansky but aimed more for the meat worker market.
you should be able to rod the left side of the blade for light sharpening and add a strop to the right for "heavier" work.
HTH
Thanks SpearHead,
You mean steal the short side only?. Then sharpen the right side when blunt. I’m from Kangaroo Land, so it takes longer to sink in!!.
