Noisy Benchmade Opportunist?
ChrisB507
I just received a new Benchmade Opportunist from knifeworks.com. Love the looks, the size and the weight…however, when I disengage the liner lock, there is a pretty pronounced gritty sound and stickiness. It’s not smooth at all... the noise is a little jarring and something I haven’t heard out of my other dozen-or-so liner locks. This liner lock really rubs hard.
So my question is: Should it go back? Is this something you think may smooth out and quiet down over a break-in period, or something that never should have made it out the door?
Try cleaning it out maybe? Could be that there are some particulates, sand/metal/dirt, on the detent ball. When my knives get that gritty feeling, that's usually what it is.
Wash it out really well with warm soapy water, then blast it with compressed air (air-in-a-can works fine). Next, use some WD40 to displace any last bits of moisture, and let it dry. Now that it's clean, drop a tiny bit of your favorite lube into the pivot.
If the liner lock still feels gritty, I find that the best thing to lubricate them with is pencil graphite. Simply use a pencil to color on the tang of the blade where the liner makes contact. Cycle it open & closed a couple times, graphite again if necessary, and you're done.
Knives often come from the factory with dirt/gunk inside; it's just part of mass production.
Thanks guys! I have clean and lubed it more than once. No help. It's still sounds like metal on metal.
It looks like the liner lock has a slight lip that sits on top of the flat, bottom edge of the blade. So, a normal liner lock looks like this, viewed from the side: liner edge-->ll<--blade
The Opportunist looks like this: liner edge-->Tl<--blade. I think I am getting the noise where the liner edge overlaps the blade, and the top lip of the liner is dragging on the blade when it's disengaged. It's odd.
