Svashtar said:
I know Yvsa ia an expert on using the super glues because I saw the super glue finish he gave to a beautiful flute he had, but what I hate about the stuff for bonding is that you open a tube and use it, and then go back a week later and the stuff is like water and useless. I just cut to the chase and use 2-part epoxy for everything now, and buy it in 90 second, 4 minute, and extended setup versions to cover all applications.
I would like to learn how to do that finish with it though, but would probably need to buy the cyanoacrylate stuff in bulk, and as I recall Yvsa said the fumes about did him in...
I don't know about being an expert Norm but I have had a little experience with the super glues.
Personally I prefer the liquid in a bottle rather than in a tube.
I used to buy a bottle of super glue, open it, and then come back a week later and find it all dried up.
A friend told me too keep the super glue in the refrigerator and it wouldn't do that, I tried it and I no longer have dried up bottles of super glue laying around.:thumbup:
Our refrigerator has a couple of small covered containers that set in the door and one of them is the designated super glue keeper.
I generally buy at least five bottles of the super glue at a time and I like to buy ten at a time because it seems to last longer.
I use a Magic Marker to mark the opened bottle.
Yep, trying to put a super glue finish on will do you in unless you have plenty of ventilation and with as much exposed wet glue as you have when using it for a finish that means outside to me.
It's been a while since I did the Flute but IIRC I used about seven or eight bottles of the Bondini II on it.
I had read about using a latex glove and spitting on the tip of one finger and spreading the wet glue with it.
I wasn't paying attention and when I bought my gloves I bought vinyl instead, still worked but a finger tip didn't last all that long until it was too hard and unpliable to use and a new glove would be needed.
Still the glove use wasn't unreasonable though and I didn't go through all that many doing the finish.
I know someone will ask how big the Flute was so here are the approximate spec's...
About 24" oal and 2" in diameter.
Start out by putting a glove on and spitting on the tip of the finger you're going to use.
Have the super glue open and ready to go beforehand and immediately squirt some glue on the wood and start rubbing, try not to let it run.
Try to build up a fairly thick coat and cover the wood as evenly as possible.
You will think you've ruined the piece by the very uneven finish but you haven't.
Using about 220 sandpaper sand the piece smooth getting the high spots off.
Then recoat and do the same, do it over and over again until you have a nice thick coat all over the piece.
As the super glue gets thicker and thicker sand it smoother and smoother each time you put on a new coat.
When the finish is as thick as you want it then it's just a simple matter of using progressive finer sandpaper to get all the scratches out and making the finish as even and smooth as you can get it.
When you get down to 1,500 grit then it's time to use the Rottenstone and oil.
Rottenstone can be purchased at fine wood supply outfits or over the Internet.
To use the Rottenstone simply oil a nice soft cloth like an old t-shirt that's been neatly folded to a piece about 2-1/2" square or so.
You want it well saturated but not dripping.
Sprinkle some Rottenstone on the cloth, be fairly generous, and then start rubbing.
The more you rub the shinier the finish will become until it's like a sheet of highly polished glass!!!!:thumbup:
You can then wax it with a good paste wax like Johnson's if you want but it's not necessary.
Super glue leaves a beautiful shiny and Hard finish that just can't be beat IMO!:thumbup:
I was pretty confident when I started and I've had lots of experience putting on hand rubbed finishes so I wasn't to worried although I did think I had ruined it to start with.
For most folks I'd recommend trying it on a piece of wood about the size of a broomstick before I started on something valuable to me.
