howiesatwork said:As far as I know, there are none. The EXTECH 42545 goes to 1832 deg F, although the accuracy up there is not too good: ±3% +9°F >1000°F...
A thermocouple measuring system is more accurate
howiesatwork said:A thermocouple measuring system is more accurate
I got carried away this morning...C L Wilkins said:That's not necessarily true, I'm afraid. Once you factor in the cold junction reference points, specifications on the TC wire and the thermocouple itself, you are looking at about the same accuracy.
I know that Leeds and Northrop used to make a portable pyrometer that would go past 2500 but they are/were very expensive. L&N makes the Rayotube and Honeywell makes the Radiamatic RH that are both non-contact thermopiles. They too are very expensive but will go well past 2500 degrees.
By the way, Honeywell bought L&N about 10 years ago.
I will check on the TC measuring device I have and will post it here later this evening.
Craig
