Still not doing to well. Tried to sharpen and old beat up Cold Steel SRK today, and, while I did get it sharper than it was, I couldn't get it very sharp. Not sure if I'm using the wrong technique (I sharpen on one side until I feel a slight burr folded over on the other, then switch and do the same on the other side), wrong angle, or not spending enough time on the stones.
Would you describe how you sharpened in as much detail as you can?
what angle are you using?
is it the original edge angle?
how much time did you spend?
what did you do to remove the burr?
does the knife wobble a lot in your hand?
what kind of stone are you using? lubricant(water) or dry?
how much force (stone on bathroom/food scale do a few passes, how many pounds)?
It
could be as simple as you did not remove the burr, so its still there just folded, not cutting paper well
or it could be instead of cutting off (removing) the burr you cut off the edge as well
cutting off the edge could happen in a few ways
you went 90 degrees and just cut into the stone
you're shaking and wobbling so much you accidentally cut into the stone
your stone has a high spot and you dug into it, the effect being same as trying to cut the stone, knife goes dull
or it could be you've raised a burr on both sides but edge is still flat/dull in the middle (I've done it lots)
if you look at your edge under a strong flashlight you will see a reflection
since you're starting,
good practice is three 5 minute sharpenings,
this is one 5 minute sharpening
use a thin 1-4 inch paring knife (short thin sharpens faster ),
using scrubbing pass (knife on stone, back and forth)
your goal is to raise a burr you can feel and see, big burrs benefit beginners
scrub for a full minute, or for a 120 back and forth passes,
then check for burr, if there is burr, flip side
if no burr, scrub for another minute
then do the same time on other side
once you have a burr on both sides
try cutting some paper
now double the angle (or go for 35-40 degrees)
and do 2-4 lighter passes per side to cut off the burr (not scrubbing, just forward, edge leading )
try cutting paper again, if its not a lot better
do another 2-4 lighter lighter passes per side
back to original angle (or slightly higher angle)
and do 10-20 light passes per side
and try cutting paper again
knife very sharp now? it didn't work?
stop, take a break, for a few minutes
counting while you sharpen or singing a song
or set an egg timer/alarm
helps you not spend an hour trying to raise a burr
break is over, usin same short thin paring knife, repeat raising burr and cutting it off a second time, 5 more minutes
then take another break
then repeat this a third time, the last 5 minutes
doing three sharpenings of the same knife should help you figure it out
or at least figure out where you need help
my problems were so much shaking and wobbling at first (up down and left right),
then it was forgetting what angle i was sharpening
so do 50 passes on one angle, then change it, then change it again ...
and i wasn't using scrubbing passes so it was very very slow
then I was going very very light (under half a pound) of force
then i was using too much my arm got sore
then I was using lower angle each time so it was always taking a long time
then I didn't count or set an alarm so it would just stretch out into half hour or more
