NOOB question about lock up
I frequently see posts here where someone mentions "early lockup" or "40% lockup". Can someone tell me or better yet show a photo that illustrates these terms clearly? I just want to understand the terminology. Thanks guys.
:thumbup:
Lockup generally refers to how far a frame-lock extends when securing a blade. When someone says the lockup is early they generally mean that very little of the lock bar is securing the blade. Generally this is believed to be a good thing because it is thought to have a longer lifespan than knives that don't.
if the lockup isn't perfect, can't you take the knife apart and grind (file) down the edge of the liner lock or frame lock and bend it a bit so it will work better?
Hmm, It seems to me that having all of the lock bar securing the blade would make it safer but that's why I asked. Thanks for the insight.
I does make it safer, just less desirable from a collector/seller stand point.
so if a knife has 100% lockup that would mean that 100% of the liner lock is in contact with the blade? If the blade is a user not for the collection then 100% lockup would be more desirable, right?
Here is a video explaining it:
[video=youtube_share;5_kIYNjD-VE]http://youtu.be/5_kIYNjD-VE[/video]
Sort of, the later the lock up, the farther the liner travels across the tang of the blade to the right. And yes 100 would be more desirable...
100% lockup would never be desirable whether it's a user or not. 100% lockup would mean there is zero room for wear and I don't see why anyone would want a folder that is completely worn out and will only develop vertical play and other lockup issues in the immediate future. For me personally anything between 50-75% lockup is the best ratio of longevity versus safety. The only exception being a CRK where I would be completely fine with a 90%+ lockup since it will pretty much take a decade or more to wear it out from that point.
