- Jul 22, 2013
What does "combat grade" mean? I see that some models, like the SOB, have come in two versions, and the combat grade was less expensive. What's the difference?
Thanks
Thanks
Combat grade means that the knife is made using Busse's SR-101 steel instead of their INFI steel. I can't give you specifics as to their differences, however if you search the forum, there will be threads with lots of info.
My bad. Got them backwards.
No it doesn't - that's Battle Grade.
Combat Grade means the blade (infi) is coated, instead of having a bare steel and more finished blade (like the satin finish of the LE (Limited Edition) or double cut, or the more recent Industrial Grade finish).
Under the coating it could be anything from a nice satin finish to almost a raw forged look with the famous infi dimples.
Infi takes a fair bit of work to get it smooth and shiny, so it's more expensive to finish it nicely. Combat grade gives us a great working blade at a cheaper price.
A picture is worth a thousand words... LE (satin finish) above, coated (effectively a Combat Grade) below:
The Special HOG Edition will be a combat grade ASH 1 with a Muddy Trough Brown Blade and Magnum Tiger Hide Handles!!!!. . . . Very Cool!!!
