I have started using O1 more often since I can get it PG in thin stock. My HT routine is:
- Preheat oven to 1200 for 20 minutes
- Insert blade for a 20 minute stress relief cycle
- Ramp blade within 10 minutes to 1480
- Let blade soak for 20 minutes
- Quench (still playing around with various quenching mediums: Peanut Oil, Canola Oil, Parks 50, Aluminum Plates, Edge quinch only, etc)
I don't do any grinding pre HT on the 3/32 stock I am using so I don't generate any uneven heat except during the profile process.
My question is, I would like to refine the grain, so that means I should normalize - 1600, 1500, 1400. But do I still need to give the steel a stress relief cycle if I normalize? If so, should I normalize, then relieve stress, then soak? Or should I relieve stress, then normalize, then soak?
What do you think?
What do you think?
