The North Face puts out good gear.
Ive had a couple of their bags, and theyre pretty solid and hard-wearing. Dont expect too much of their cheaper bags. IMO theyre primarily built for urbanites who want to look wilderness chic. But the more expensive line-up, is pretty good. There are some serious technical hiking packs to be found.
But if you want the best there is for hiking-duty only, then you can do much better. Take a look at Osprey.
I could not have put it better myself and and in terms of cost you will be hard pushed to find anything better than Osprey.
Backcountry.com have excellent pictures of this pack (
http://www.backcountry.com/the-north-face-hot-shot-backpack-2015cu-in) which allow you to see the weaknesses, and for a pack with that capacity both the should straps & waist belt are terribly lacking, another deal breaker for me would be the defined purpose of this pack:
Recommended Use: school, work
A well designed backpack will hug your body (ergonomically) whilst still allowing freedom of movement and very importantly, allow your body to breath! Maintaining the weight close to your center of gravity, and over your hips significantly increases efficiency.
If a pack fails to do this it simply adds additional inertia to every step, and over a 3-4 day hike it will become uncomfortable. Given the relatively short length of the pack, and considerable depth means that you will be carrying the weight higher on your back, not
such a problem going from car to office or office to subway but on the trail could be terrible, and you will be too far from civilization to do anything about it.
I personally would not take that Northface on the trail since I think it's too small. I have three Osprey backpacks and it is really hard to find fault with any of them.
Same capacity, better form factor and much lighter:
http://www.backcountry.com/osprey-packs-kestrel-32-backpack-1800-2000cu-in
Two packs which I think are more suitable for 3-4 day hikes:
Very lightweight & more edc friendly, however not quite as durable as the next
http://www.backcountry.com/osprey-p...in?rr=t&cmp_id=&rrType=ClickEV&rrProd=OSP0188 (You could EDC this as well)
Still lightweight, not as edc friendly but much more durable and more suitable for 3-4 day hikes, I have this and it's an incredible backpack
http://www.backcountry.com/osprey-packs-kestrel-38-backpack-2200-2300cu-in
The Osprey packs are more expensive, but you get what you pay for.
