Handmade "coffee holder"
This is the moment I took the case.
One of the most curious to manufacture products.
If the same amount of "coffee on the shelf" for
Should be considered the most advanced product of it!
Although not a knife.
However, production methods and materials are related with the knife.
Steel is. 1086 + L6 level 〔85〕
"L frame with horseshoe-shaped socket" are of the same material.
Parts are. Bronze.
Handle material is. Meng Ma fossil ivory. Nail mosaic spiral arrangement 〔〕.
Chuck is a sample of the original using the original chuck.
The whole group is "detachable" production methods.
Difficult.
When orders started.
Production should be no more difficult to imagine.
But to really make it know that "difficult ah!"
The first is "L frame"
Was going to say the system should be sent to the turning vehicle.
Thought that they have forged a very straight. There remain thick〕 〔
But the one on the lathe on the eccentric of the.
The end, no way
Please car manufacturers were about 3 cm long, round
To do some quick reference other sections of the 20 cm〕 my hand until it has.
This solution has the same problem.
But do not over yet!
Tripod is said than done ~
Because Au into the "horseshoe-shaped"
It is challenging too!
Because both sides of the middle of wide thin
Therefore, always in heated curved concave on both sides of thin
First bend.
And on until a long time. . .
Finally think of oil press repression before solving the problem.
Conclusion.
Do this kind of work I really enjoyed making fun of them.
I finished goods and the customers are satisfied.
High variability big challenge I like the feeling.
Okay. Tour map it!
手工製煮咖啡架
這是目前我接過的案件.
最奇怪的製作產品之一.
如果以同款項的煮咖啡的架子來說
應該算最高級的產品了吧!
雖然不是刀子.
不過製作手法及材料都是與刀子相關的.
鋼材是.1086+L6 〔85層〕
  L架跟馬蹄鐵形腳座都是同材質.
配件是.青銅.
柄材是.猛瑪象牙化石.馬賽克釘〔螺旋式排列〕.
夾頭是利用原來樣本的原廠夾頭.
整組是可拆式的製作方式.
難度.
一開始接單時.
想像製作應該沒有多困難.
可是到真正製作才知道難做啊!
首先是L架
本來想說要送去給車床車製.
本以為自己已經鍛造的很直了.〔有留厚〕
可是一架上車床就偏心圓了.
最後還是沒辦法
請廠家車個約3公分長的圓
做基準其他〔約快20公分〕我用手工磨出.
這樣就解決一樣難題了.
不過事情還沒結束呢!
腳架更是難啊~
因為要凹成馬蹄鐵形
那才是具有挑戰性呢!
因為要中間寬兩邊細
所以在加熱後彎凹總是細的兩邊
先彎曲.
一直折騰了很久...
最後想到用油壓機壓製才解決問題.
結論.
做這種作品我真的是很享受其中的製作樂趣.
完成品我及客戶也都很滿意.
挑戰性高變化性大我喜歡這種感覺.
好了.賞圖吧!
Parts are. Bronze.
Difficult.
The end, no way
First bend.
Conclusion.
Okay. Tour map it!
手工製煮咖啡架
這是目前我接過的案件.
最奇怪的製作產品之一.
如果以同款項的煮咖啡的架子來說
應該算最高級的產品了吧!
雖然不是刀子.
不過製作手法及材料都是與刀子相關的.
鋼材是.1086+L6 〔85層〕
  L架跟馬蹄鐵形腳座都是同材質.
配件是.青銅.
夾頭是利用原來樣本的原廠夾頭.
整組是可拆式的製作方式.
難度.
一開始接單時.
想像製作應該沒有多困難.
可是到真正製作才知道難做啊!
首先是L架
本來想說要送去給車床車製.
本以為自己已經鍛造的很直了.〔有留厚〕
可是一架上車床就偏心圓了.
最後還是沒辦法
請廠家車個約3公分長的圓
這樣就解決一樣難題了.
不過事情還沒結束呢!
腳架更是難啊~
因為要凹成馬蹄鐵形
那才是具有挑戰性呢!
因為要中間寬兩邊細
所以在加熱後彎凹總是細的兩邊
先彎曲.
一直折騰了很久...
最後想到用油壓機壓製才解決問題.
結論.
完成品我及客戶也都很滿意.
挑戰性高變化性大我喜歡這種感覺.
好了.賞圖吧!
