Dawkind
Platinum Member
- Apr 3, 2000
This is my rendition of an Imada High Hollow. I used 1095 high carbon 3/16" steel for the blade, 6061-T6 aluminum for the handles, and turned pins from hardened button-head machine screws. I used Nylatron .010 washers between the blade and handle. No latch, no taper, just wanted to figure out where to put the holes! Manipultes real well; milled grooves to distinguish the safe handle. It's hell for stout and now I'll see if I can wear it out! I ground the blade to shape at full hardness to 500 grit and then tempered and thermally cycled it 3 times......The color of the blade is from the tempering process and is what color carbon steel turns after being exposed to 500`. Something a little different
Here's some more
http://albums.photopoint.com/j/AlbumIndex?u=667533&a=9093279
