It would also help if you told us more of your process, at the moment we really don’t have much info to give advice on. What are you heat treating in? I’m assuming your using a forge but I don’t know, what temp did you quench at and what quench did you use? Canola oil? Parks 50? Water? Something else? To be honest you should be quenching it into one of those three for that steel, canola works just fine but parks 50 would be more optimal. What temp did you temper at in your oven, 1084 if you have a optimal heat treat meaning right temp before quench and optimal oil, parks 50, at 400 degrees should be around 60-61rc, if it was me I would probably temper the axe closer to 450-500 and even then I may take a torch and draw back the spine to add some more toughness to the overall blade, or the alternative is to edge quench but then your pattern won’t be as nice as a fully hardened blade. Then after all of that we need to look at how thin your grinding the edge if you grind too thin even with a optimal heat treat you could have a brittle blade that chips. Think about master smiths that make swords on forged in fire that end up with major chipping during testing, I would assume they know what they are doing for heat treating but if you grind your bevels too thin, think of Japanese kitchen knives, then the steel doesn’t have as much support for chopping. So take some calipers and measure the thickness of your steel just behind your actual edge to get an idea of where you are at. The final thing is edge angle, a 10 degree edge angle even if all else is right will be prone to chipping vs say a 25 degree angle. Maybe make a test blade from just plain 1084 and play around with the heat treat, temper, behind the edge thickness and finally the edge angle then dial it in so it functions the way you want before making it from 1084/15n20 Damascus. With everything right that steel combination should work just fine you just have to adjust things to make it optimal.
