- Apr 14, 2006
Many of you might remember my story of how I built a KMG clone and put a 2hp 3ph motor on it. I hooked it all into my VFD and it all seemed good except not enough power. It kept bogging down. I tried everything I could think of. Even calling a friend and asking his advice, he makes a living building stuff like this. The only thing I could come up with was I needed more power. So I purchased and installed a rotary phase converter, (wanted one anyway just needed an excuse). Found a new 5hp 3ph on ebay for $150 delivered. Then modified the grinder for an interchangeable 2 motor system. The 5hp worked great. I could grind with all the pressure I could push and still maintain control. HALLELUJAH, It worked finally.
Well yesterday I was doing some handle work so I needed to slow down the grinder so I switched it to the 2hp. Something seemed off. It took a really long time to come up to speed. Even longer than before. It seemed the belt needed to be tightened. SO I took a link out of the belt and put it back together. HOLY CRAPOLA it came right up to speed. Well if that was good let's try heavy grinding. WOW IT REALLY HOGS IT OFF NOW. All that for a #$%#^$%&^#%$&&#* loose belt. Well at least now I have a nice 5hp backup for my power hammer and brand new wiring in the shop for the 3phase rotary inverter. Lesson learned here, check the darn belt to see if it is tight enough before rebuilding the whole shop.....
