- Mar 10, 2011
Last week I showed this poor beat up Nickel 112...and a few wanted to see a thread on its restoration so here goes...
here it is as found...
[/IMG]
and after about 1-1/2 hours of sanding with 80 then 120 grit sheets folded in 1/3 lengthwise....
sanded knife closed on each side till rivet heads gone and all dings/gouges dissapear.
sanded knife open on spine of blade and backbone to insure that lockbar will be flush with blade and frame when open...
when closed, who cares?
the lock bar depression was done with a sanding drum on a dremel then finished by hand...
the well area done with a round sanding stick...basically a 1" dowel.
all radiusing done by hand...
[/IMG]
[/IMG]
Now it's time to pop the scales, remove rocker pin, remove pivot pin and blade...(there was play fore and aft...)
(at this point I usually de-bur rocker bar and frame of knife)
cut and peen new rocker pin.
cut pin and re-blade (too much for here )
and this brings us to this point...ready for some new "shoes"
[/IMG]
Here is my high-tech scale making factory
[/IMG]
my Scoring tool ! for me the flats are the most important...
[/IMG]
And these guys, to sand 'em in a little closer once they are glued on...
[/IMG]
[/IMG]
once I get my scales to fit to this point I glue them on one at a time.then sand to fit, and later finish the knife
[/IMG]
