- Apr 22, 2022
I’ve noticed when using Nuclayer 2000 anti-scale on 1084 test coupons that hardness is reduced an estimated 3-4 Rockwell points (Rockwell files and skate test with a Nicholson course bastard file). I used .140“ 1084 from AKS (Alpha) and soaked at 1500 for 10 minutes. The oven was equalized for at least 30 minutes before soaking the coupon. I heat treated a blade today with the same steel, thickness and procedure without the Nuclayer, and I’m pleased with the hardness. It seems the Nuclayer would be fine for doing Normalization and DET anneals, but I don’t think I will be using it for heat treating. The Nuclayer was applied very thinly and I used Parks 50 to quench. What gives? Do other anti-scale compounds do the same thing?
Thanks,
Scott
Thanks,
Scott
