Progunner said:I wouldn't put much stock in what numbers you see. The past has proven them non sequential and not a true judge of how many were made.
In retrospect, I wish I had talked to the shop when I ordered. I would have preferred this also. I have a sterile HOFSH-LE and it just seems "righter".SNAFU said:Thanks Progunner, I guess I'll see what I can get when Skunk gets them in. I actually would even prefer if I could get one that was sterile.
SNAFU said:Thanks Progunner, I guess I'll see what I can get when Skunk gets them in. I actually would even prefer if I could get one that was sterile. :thumbup:
idahoskunk said:the "store", to avoid confusion, is having their SJLE's numbered in reverse.
our numbers are going to start at three hundred and run down to zero. this way we collectors will be able to distinguish between the sjle's sold via busse's site vs. the stores site.
in the futures all our numbering will be this way.
moderator please make this a sticky![]()
well jerry's numbers started at 1 and ran up to the hundreds. we just asked him and he agreed to start our numbers where he ended and run them back down to 1rbmcmjr said:I guess I don't understand. Will there be some other distinction made? I can envision a situation where the two schemes overlap (e.g., you both sell two hundred). Maybe I overestimate the volume sold.
I still don't understand how this works. You say Jerry started at #1 and sold into the hundreds, So this means he probably sold one with say #200 on it. The Company Store is starting at #300 and going down to #1. This means that the Company Store would have one with #200 on it. How will you be able to tell which one came from who? Will the reversed version read like 002# or 200#.idahoskunk said:well jerry's numbers started at 1 and ran up to the hundreds. we just asked him and he agreed to start our numbers where he ended and run them back down to 1
100, 99, 98, 97, 96 and so on and so forth till he hits 0.
other than the reversing of the numbers all will be the samo.![]()
you probably want number 1 or zero right?Progunner said:Not a bad idea Scott. Looking forward to getting one from you and a couple of Rippers too.![]()
idahoskunk said:you probably want number 1 or zero right?
