- Oct 4, 2000
hi all,when i heat treat O-1i use carl schroen`s technique,coffee can , 1/3 borax , the rest filled with water ,bring to a boil,making sure all the borax is dissolved,you are ready to dip the blade.Now i used to only dip the blade in once or twice but now i dip at least 10 or 15 times with about 5 seconds between dippings,once done dipping i hang over the wood stove to dry (10 minutes or so) it dryes clear once dryed i fire up the forge run it real cool and run the blade in and out a bunch of times,watching the borax mixture on the blade turn from clear to a frosty sorta look then it`s ready to heat treat,i heat evenly till the magnet doesn`t stick and then heat just a bit more , then go instantly from forge to vegetable oil heated to 130 degrees and what used to be scale i guess is what i call it you know the black crap that is hard to sand off,but anyway the scale just flakes off and if you coated the steel good enough you will have little to no scale sanding at all i go right into sanding for a mirror polish.the only thing i do different from years before is dip the blade a whole lot more...saves a lot of greif
sorry for writing a book for ya all hope it`s helpfull!
i keep grinding and grinding and it is still too short!!
