there have been several references to O-1 recently, and I think it should be pointed out that it is not the same as simple 1095 in it's heat treating characteristics.
I would assume (perhaps incorrrectly, but I doubt it) that most of you that are using O-1 are buying precision ground annealed flat bar and grinding blades via stock removal, and not forging. If this is so, then the steel really should be soaked at temp for a few minutes before quenching, or it will not achieve full as quenched hardness. The structure that you recieve from the mill in the steel is a full spherodize annealed structure. That means spherical carbides of rather large size (reltively speaking) in a nearly pure ferrite matrix. These large spheroidal carbides take a while to dissolve (longer than the lammelar pearlite of annealed 1084/1095) and they are also complex carbides due to the tungsten and chromium of O-1, whereas the simple 10xx steels do not have either, and everything goes into solution much quicker.
If the O-1 is heated to 1525-1550F (generally accepted practice) it takes about three to four minutes to get enough carbon into solution to get HRC 62 for as quenched hardness. Lower the temp, or shorten the time, and you don't get full hard upon quenching. That can also be ok, but it affects the tempering temperature a great deal. If you hit full hard (HRC 62-64) then the tempering temperature to drop the hardness to HRC 59-60 needs to be up around 475 to 500F.
If the austenitizing temperature was low (less than 1500F) or the soak time was very short, the as quenched hardness will be lower, and the tempering temperature will also need to be lower to preserve the hardness you have.
A very decent job of heat treating can be done on O-1 with simple stuff, but it is not neccesarily a "one size fits all" kind of thing.
I encourage experimentation with careful observation and destructive testing of your work. It doesn't hurt to also keep notes.
