O.T. Definitely Try This At Home!!!
If you have a remote control door opener for your automobile, determine the distance in which it begins to function... Step back another 20 feet and try again; it definitely doesn't function, does it? Place the font end of the unit against the side of your head (perpendicular to your skull and pressed against same)... Press the button... :eek: What happens, and would any physicist care to explain? :confused:
This is a great conversational experiment for all of us who go to work in the morning. :D Have fun teaching the technique to your colleagues... ;)
I'm pretty sure the contact lets your whole body act as an antenna. Been doing it ever since some little blonde showed me the trick. A few years back some outfit had a TV antenna that plugged into an outlet. It let the tv use your home's wiring as an antenna. :)
It works, as long as you don't mind putting an extra bit of electromagnetic energy through you head... :eek:
I just got a new SUV with a remote that has a panic button on it. My older cars didn't.
New electronic gizmo for me.
I was in the kitchen or livingroom (driveway out the window), when a car horn started blasting. I looked outside to see what it was, and nothing. No vandals or burglers.
Went in the house, and it started again.
Looked outside, and no one was there.
I was setting off the alarm.
I had the remote in the same pocket with other keys - lots of them. Any sudden move set off the panic button. Horns blared, lights flashed....
No more.
The car key goes on a hook when in the house, and in a separate pocket when I am outside.
I really don't like the remote entry system.
does this trick work equally well if you place the remote against the side/front of other organs or body parts? :p
That depends on the length of the um...antennae.
v
Now I gotta try this. My friends will think I'm even more bonkers than usual! :D
Nam
Yvsa said:
What does it do, make your zipper go up and down? :rolleyes: :p :D ;)
Is that what happened to you when you followed the prodedure... :eek: :D
It's NOT SUPPOSED to do that, but may work differently on different folks; you might have an unusually large antenna if this happened, and I'm sorry if you were publicly "compromised"! :rolleyes: :D :
Drdan said:
Is that what happened to you when you followed the prodedure... :D
Heavens No!!!! I don't even own a garage let alone an opener for one!!!! :p
I'm setting in what used too be the doorway too the garage on my house. I enclosed the garage door and knocked out the living room wall to make a living room big enough too swing a cat in.:eek:
Not everyone can afford a 20 room villa with a four car garage and a new Lambo.:rolleyes: :p :D ;)
And A Garage Door Opener! :rolleyes: :D
Yvsa, living frugally in Oklahoma.;)
Kismet said:
Living frugally?
You're one of the richest men I know. :D
You've got that right Kis, and I'm wearing my, "I'm Rich And Famous" t-shirt right now.
But I'm still living frugally in Oklahoma.;)
Barb and I would really like another bathroom, or a two holer like my Uncle Bud had, and a bigger bedroom but at least we can afford too heat And cool our little house in the 'burbs as well as enough food too keep us both overweight.;)
Not much more a person can ask for.:D
