- Dec 11, 2000
I have started to file my first blades from O1 tool steel. I have been looking ahead to how I am going to get them heat treated.
The place I work has both an atmosphere furnace and a vacuum furnace, and the guys who run them dont object to my running some blades through them. Question is, which to use, and how should I set things up.
The vacuum furnace gets heated up from cold, so that will provide a pre-heat, the atmosphere furnace though is on all the time at a minimum of about 1380degF (bit high??). On the other hand the atmosphere furnace uses a hot oil quench (about 175degF) whereas the vacuum unit uses gas (Im not too clear on this, been told that it can achieve different quench rates).
In the case of oil quench I have read that the blades have to go into the oil vertically, point first, to prevent warping. How badly can a blade warp if quenched length-ways, edge first? The furnace runs with a conveyor belt, stuff goes in on a rack and gets heated and quenched in whatever orientation it gets put in with. Do I need to wrap the blades?
I can go and ask questions in the heat treat area, but I am so new to this that I still dont know what the right questions are
I dont live in the US, if I did I would be sending my first blades to someone who knows exactly what they are doing. Round here though, knife makers are even rarer than legal gun owners!
Hope that some of you guys can help me out.
Thanks
Chris
[This message has been edited by C_Claycomb (edited 01-12-2001).]
Thanks
Chris
