- May 12, 2010
I'm a stock removal guy. I've been using Aldo's 1084 with good success. I decided to try some O1 because I can pick it up locally. Using 1/8" O1 I made 6 small utility/paring knives and a couple of 10" and a 6" chef knives from O1 with no problems and all pass the file test. I normalize once or twice, then raise to non-magnetic, let soak for about a min. and quench in heated canola oil with a little motor oil used just to top off my quench tank.
I used the same procedure over the weekend on 6 more O1 1/8" steel chef knives ranging from 6" to 10". One warped and all failed the file test. I went ahead and tempered them at 400 F for two 2 hour cycles just to see if that would effect anything. Which it didn't
So tonight I decided to re-normalize them three times, raise to non-magnetic, soak for a min or two, then quench. Sill can't pass the file test. And now at this point I have several blades showing noticeable warppage. Since the forge was hot I figured one more try on another blade and still failed. At this point I sacrificed one of them and broke the blade to see what was going on inside; creamy dull grey is the best way I can describe it, no sparkly crystals visible to the naked eye at all.
I don't think I changed anything in my procedure from the O1 knives that I already made that came out fine. I'll go back to Aldo's for 1084 for future projects but can anyone help me save these knives? Let me know what I'm not doing right? Quenching too hot or too cold?
Thanks for the help.
